21 years agoASMI & Flash programmer
Similar to the epcs_controller, the asmi component has extradelay set to "1" causing an increase in programming time. As a simple example, my 5.0 design takes 6 minutes to program my design into a...
21 years ago> It's a minor change not a bug (without this change your device still programmed right?)
I suppose we should be grateful ... right? Please don't be smug about this. There is far more to this issue than just programming an epcs device. When an issue can affect business it is certainly appropriate for a customer to expect some documentation ... it's not unreasonable. When you upgrade from 4.2 and extradelay=1 remains in your ptf and suddenly your design doesn't meet the minimum startup time requirement ... it's a bug. When device access time is too slow to meet application deadlines after an upgrade ... it's a bug. When you remove, then add an asmi component to your flash programmer design and SOPCBuilder can't generate the system ... it's a bug. These types of problems are not new ... they happen, we fix them, and we move on. No one is complaining about bugs here. As customers we do our part: we contact tech support, we post solutions to benefit others, and we install/test patches. That being said, some simple documentation goes a long way to saving time, effort and money. But on to the more practical: tns1, I didn't install the update on my other machines yet ... I just did the manual stuff on the primary system. Did you notice if the following file was corrected as well: altera_user_board_setup/system/ABSTRACT_BOARD.ptf.template Regards, --Scott
