21 years agoASMI & Flash programmer
Similar to the epcs_controller, the asmi component has extradelay set to "1" causing an increase in programming time. As a simple example, my 5.0 design takes 6 minutes to program my design into a...
21 years agoDon't get me wrong, minor fixes are better than no fixes, but what is minor to one is essential to another. If I had not already fixed the extradelay manually, I'd gladly recommend each team member spend the 30min needed to install the patch. Either way, I'd sure like to know what else was considered minor - it may be at the top of my short list.
1) Anything to do with improving the robustness/performance of the serial ports. 2) Anything to do with improving the operation/robustness of the debugger - seems less robust than 4.1. 3) Any improvements to the project management features - how about a 'save project as' menu item, and a way I can specify just the project root folder and not have to manually add 20 pathnames? keep up the good work
