sirujjan's avatar
sirujjan
1 year ago
Ashling RiscFree IDE not listing my NIOS-V processor in debug config
Hello everyone
I recently upgraded my Quartus from 18.1 to 23.1. As my first qsys design, I replaced NIOS-II with NIOS-V/m. Connected all interfaces as per the online relevant guidelines.
Qsys system generation is successful,
project full compilation in Quartus is successful,
program run in programmer is successful,
bsp creation is successful
Instead of Eclipse IDE, downloaded Ashling RiscFree IDE and installed it. Following all the necessary steps for creating app and bsp through command line and then BSP editor worked fine.
While creating BSP, after selection of sopcinfo file, I could witness my NIOS-V processor was referenced and hence bsp was successfully created. All the further steps were followed, build of the project was successfully.
Now at the turn when I am setting debug configuration for running my project, in the debug tab I am unable to list down and see my NIOS-V processor. It is because of this I cannot start debug or run process.
In tutorials and examples, I can notice the debug and run configurations include the option 'Ashling RISCV (auto-detect) hardware debugging' while in my PC it is 'Ashling RISCV hardware debugging' without auto-detect.
I am using Quartus Prime Standard Edition 23.1; Ashling RiscFree 23.4.1
My Intel board is DE-4 with Stratix-4 FPGA. Please check the attachments and kindly respond - Thanks
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    There are some reported bug that is similar to what you are reporting where the core is not being detected in the drop down list.
    Could you try getting the latest RiscFree from the Quartus 24.3?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Jingyang,Teh
