13 years agoAS Configuration of NiosII hardware & software images
Hi, I have a requirement that I want to program my serial configuration device - EPCS16 with the hardware and software images of the NiosII system that I am building. Upon power-up, I want the FPG...
13 years ago --- Quote Start --- Do you have any white paper / application note for generating a single .pof file for both the hardware and software images. --- Quote End --- I had an application note but I can't remember where it is right now. I'd have to search for it. Try browsing the Altera documentation. You basically only need the steps I mentioned before: - generate the hex memory initialization file for your Nios software. I think the Nios tools have an option to generate this hex file in addition to the standard elf file. - assign the hex file as initialization file for the onchip memory in Qsys/sopc-builder - rebuild Quartus project and generate pof file --- Quote Start --- One more doubt: upon power up, once the hardware and software images are loaded, what is that "thing" which makes the NiosII processor execute the code residing in on-chip memory. --- Quote End --- You must open the Nios properties in sopc/Qsys and set the reset vector to point to onchip ram base address
