13 years agoAS Configuration of NiosII hardware & software images
Hi, I have a requirement that I want to program my serial configuration device - EPCS16 with the hardware and software images of the NiosII system that I am building. Upon power-up, I want the FPG...
13 years agoIf your nios code has access to the outside world then you can also include code to update the epcs via software - and also only update the code part.
If your code fits in internal memory you might have a space problem doing that though. However you might be able to request the individual bus cycles from the external system with minimal (or no) software support. Getting non-jtag programming working is useful - especially if the software is being written outside the hardware team (which I'd have thought was more normal than the Altera build scheme implies).
