13 years agoAS Configuration of NiosII hardware & software images
Hi, I have a requirement that I want to program my serial configuration device - EPCS16 with the hardware and software images of the NiosII system that I am building. Upon power-up, I want the FPG...
13 years agoSure it's possible.
There are usually two ways to run Nios code from configuration device (i.e. not booting with jtag) The first one is what you are asking for. The code resides in onchip ram and is loaded together with fpga configuration. To do this you must convert the Nios software elf output into a hex file which is then assigned to onchip ram as memory initialization file. The disadvantage of this method is that it requires a Quartus recompilation (actually only a MIF update is needed) whenever you change the Nios program. Usually you may want to store Nios software separately into the epcs, so you can update it without changing the fpga image file. In this case you need a bootloader which loads program data from epcs into onchip ram (or sram, or sdram or whatever) just after fpga configuration has been loaded and activated. The standard epcs controller core already provides a boot-loader feature.
