9 years agoArria10 U-boot make error using Ubuntu 14.04
I am attempting to compile Uboot and the Uboot DTS for the Arria 10 SoC dev kit per the instructions on the GSRD on https://rocketboards.org/foswiki/view/documentation/a10gsrdgeneratingubootanduboot...
PJais1
7 years agoHello,
I am having same error , but it is not getting resolved by including above packages, Also while entering : sudo apt-get install ia32-libs lib32stdc++6 , error occurs.
Package ia32-libs is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
lib32z1 lib32ncurses5 lib32bz2-1.0
E: Package 'ia32-libs' has no installation candidate
Which tar.gz file you have downloaded for the uboot source code and have you used any build command before make?
I am following https://rocketboards.org/foswiki/Documentation/A10GSRDGeneratingUBootAndUBootDeviceTree for uboot binary.
can you provide any solution.
