9 years agoArria 10 with separate hardened DDR controller for PL and HPS
I have come up with a set of requirements for the memory and I realized my PL memory needs are critical. I understand there is a x72 DDR4 hardened PHY+Controller+MPFE in the Arria10 and I'd like t...
9 years ago --- Quote Start --- Is there linux support to access FPGA DDR? --- Quote End --- Are you saying you would like to use HPS to access the FPGA DDR memory over the H2F bridge? Right now I don't think the HPS can support 2 memory controller instances (one in its own HPS DDR and the other FPGA memory) - besides, it would be quite inefficient to do it over the H2F bridge. I believe letting the FPGA access the HPS DDR over the F2S bridge is a better alternative.
