8 years ago
Arria 10 EPCQL Controller
I am trying to program my EPCQ-512L from the HPS running Linux. I have the Altera Serial Flash Controller connected from its avl_csr and avl_mem connected to the HPS using the hps2fpga lightweight bridge. I have tried to write the EPCQ and have been successful in writing zeroes. From what I have gathered, I need to erase the sector, then write my values because it erasing sets all the values in the sector to '1'. Here lies my problem; following https://www.altera.com/en_us/pdfs/literature/ug/ug_embedded_ip.pdf , starting on page 153 about the Altera Serial Flash Controller I tried to write to the FLASH_MEM_OP register to erase sectors. I tried writing 0x2 to the register to erase the sector data, but nothing seems to change. I have tried writing other values and from what I can see (when reading the values back from the epcq) there is never a change. I also tried reading the status register to see if there are processes occurring, but it always reads 0.
Also when I try to read either the FLASH_RD_SID, FLASH_RD_RDID, FLASH_ISR, or FLASH_IMR, the HPS seems to stop responding and I need to reload my .sof. I use either ssh terminal or serial terminal to communicate with my system and when I try to read any of the mentioned registers, the system stops responding on both ssh and serial. I have other signals connected to the lightweight bridge and I have not run into this symptom before. I think this could be part of the problem; maybe the control register is not working at all, but I am not sure where to start debugging this. Any help or points in a direction would be much appreciated.
Thank you in advance :)
    I am using Cyclone 10 LP and Altera Serial Flash Controller II IP core. I am using Quartus Prime standard edition, V17.1 In my case also, it hangs when erase function is called. In both of following functions, alt_erase_flash_block and alt_write_flash erase routine is called and hence when I call any of them, it hangs.
    In alt_epcq_controller2_erase_block function, I made following change. (remember this is a manual change. Hence if you generate BSP again, this will get lost.)
    Instead of following
    /* write enable command */
    mem_op_value |= ALTERA_EPCQ_CONTROLLER2_MEM_OP_WRITE_ENABLE_CMD;
    I used following:
    /* Unprotect flash. */
    mem_op_value |= ALTERA_EPCQ_CONTROLLER2_MEM_OP_SECTOR_PROTECT_CMD;
    Not sure how it works. But it works! With this, it no longer hangs. (P.S. I got this idea by looking at flash_qspi.c file.)
    Perhaps somebody from Intel team might be able to give some insight into this.
    Cheers,
    Bhaumik
