8 years agoArria 10 EPCQL Controller
Hi, I am trying to program my EPCQ-512L from the HPS running Linux. I have the Altera Serial Flash Controller connected from its avl_csr and avl_mem connected to the HPS using the hps2fpga ligh...
8 years agoHello,
I am using Cyclone 10 LP and Altera Serial Flash Controller II IP core. I am using Quartus Prime standard edition, V17.1 In my case also, it hangs when erase function is called. In both of following functions, alt_erase_flash_block and alt_write_flash erase routine is called and hence when I call any of them, it hangs. In alt_epcq_controller2_erase_block function, I made following change. (remember this is a manual change. Hence if you generate BSP again, this will get lost.) Instead of following /* write enable command */ mem_op_value |= ALTERA_EPCQ_CONTROLLER2_MEM_OP_WRITE_ENABLE_CMD; I used following: /* Unprotect flash. */ mem_op_value |= ALTERA_EPCQ_CONTROLLER2_MEM_OP_SECTOR_PROTECT_CMD; Not sure how it works. But it works! With this, it no longer hangs. (P.S. I got this idea by looking at flash_qspi.c file.) Perhaps somebody from Intel team might be able to give some insight into this. Cheers, Bhaumik
