13 years agoARM DS 5 script to initialize and load code in SDRAM
Hi, My question is regarding the HPS core in Cyclone V SoC. I have successfully built and run sample code that came with ARM DS 5 using USB Blaster II interface. The code by default runs ...
11 years agoThis is interesting, I'm working with a Cyclone V board but there isn't a board specific example how to use hardware.
The HPS has 2 ddr3 SRDAM chips and the FPGA also has 2 DDR3 SdRAM chips. How do we write to the controller in binary mode using a constant pointer? I'd like to load up SDRAM but be able to write the hardware based on bytes in SDRAM. There was no hardware library for this board, so I have to implement constant pointers to registers. Is there SDRAM0 and SDRAM1 variables or what are the variables used in ARM DS-5 for all hardware?
