12 years agoARM DS-5 device_browser.py failed
Hi, guys! I use the Quartus II 14.0 and ARM DS-5 Altera edition under CentOS 6.5 x64. I followed the ug_soc_eds.pdf guide to debug a baremetal program. During the configuration of the debugger, ...
AJama4
7 years agoI also ran into the same problem on Windows using the latest 19.1 edition (v5.29.2). The problem was solved when I ran the Ds-5 through the Embedded Command Shell. So there is a difference between directly starting it from Start menu and using the Embedded Command Shell. To avoid the errors, use the latter way.
