12 years agoARM DS-5 device_browser.py failed
Hi, guys! I use the Quartus II 14.0 and ARM DS-5 Altera edition under CentOS 6.5 x64. I followed the ug_soc_eds.pdf guide to debug a baremetal program. During the configuration of the debugger, ...
11 years agoHi,
I'm sorry you are having this problem. I have a couple of questions for you:- What is your QUARTUS_ROOTDIR actually set to in your DS-5 environment? Does it point to a 64-bit Quartus installation?
- Critically, have you actually exported the variable instead of just setting it in your shell?
- Can you run 'ldd <actual libjtag_client.so>' on the library you expect to be using? It should be something like $QUARTUS_ROOTDIR/linux64/libjtag_client.so
