15 years agoArgument passing to C Main using Nios II IDE
Hi, It would be very helpful if any of you can tell me If I can pass arguments to Main function in a C program using Nios II IDE, either using GUI or shell. I know how to run without arguments ...
15 years agoHi, Thanks for the prompt reply. I will try it out.
I actually need to demonstrate buffer overflow attacks in embedded systems, which happens when you pass arguments with size more than the allotted memory.
