20 years agoAre Avalon UARTs useable as eCos /dev/tty ?
I can't get working correctly a simple application that reads bytes at 115200 bps under eCos using "hardware serial device driver" (Avalon UART) : I get one byte each two. However, the (almost...
20 years agoHi Fred,
Sorry Fred, we've never used eCos (or even HAL) so can't help any further with that. It sounds like your problem isn't the one I suspected - but it would be interesting to see if you get all characters when a slower Baud rate is used. Good luck. Banx.
