20 years agoAre Avalon UARTs useable as eCos /dev/tty ?
I can't get working correctly a simple application that reads bytes at 115200 bps under eCos using "hardware serial device driver" (Avalon UART) : I get one byte each two. However, the (almost...
20 years ago --- Quote Start --- originally posted by frd66@Jun 13 2006, 02:17 AM thanks banx,
actually, my system does just nothing for now.
it's why i am quite worried about futur with this os on my system.
i've tried with a slower system tick (100 hz), but it isn't better.
do i have to unmask interrupt or something like that before using this driver ?
-- fred
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16147)
--- quote end ---
--- Quote End --- There are two drivers polled and interrupt driven, you should not be manually interfering with interrrupts this should be left to the driver. Without looking at your entire application it's tricky to diagnose the problem, I suggest you follow the instructions to get one of the examples working on a development board, once you have that working then try to build your application on this board, then try your own hardware.
