20 years agoAre Avalon UARTs useable as eCos /dev/tty ?
I can't get working correctly a simple application that reads bytes at 115200 bps under eCos using "hardware serial device driver" (Avalon UART) : I get one byte each two. However, the (almost...
20 years agoHi Fred,
I had something similar to this happening to me. Whilst Rxing at higher Baud rates (including 115200) I would occasionally lose characters. It turned out to be a timer interrupt, of higher priority, occasionally taking longer to complete. If the timer interrupt lasted more than 400uS then that was long enough for the UART to Rx 2 characters, one in the holding register and one in the shift register - anything else has nowhere to go. I fixed the problem by giving the UART a higher priority in the SOPC builder, this didn't cuase any problems, for me, as the UART irq is very fast - just buffers the character into a ring buffer for later processing. Banx.
