21 years agoArchiving Nios II project
I would like to be able to add to my source control system the minimum set of files that are required to reconstruct my project and its associated syslib. I would also like to know what procedures I...
21 years agoI'm probably not the best person to comment on what you need for the SOPC builder project.
But from the software side, you will need to archive both your application project and your system project. You should check all the files in the same directory as the <project>.stf file. You should not check in the Debug or Release directories. After checking the code out of the version control system you should change to the directory containing the application project and run `nios2-build-project` from the command line.
