20 years agoApplication timer
Hi, I'm trying to write an application that polls at regular intervals my hardware via serial port. What I need is an event that calls a function at regular times without charge the CP...
17 years agoHello, fyi (if someone found interesting this topic)
we made some other tests and the driver and the uart seem to work correctly together. We have some troubles with the scheduling in the application. We had to lower the system timer frequency... Does any experienced programmer knows if the scheduler has grown in complexity enough?
