20 years agoApplication problems
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Hi,all I have some difficulties in running an application on nios2-uClinux. 1. I generated hello.exe and add it to target/u...
20 years agoHi Singerpop!
I've you try to execute "hello" from linux console it should works instead of "hello.exe" if it in the correct format. What want you to do with an .elf or .tlf file? You can build an executeable file in the Nios II IDE and add it to a linux filesystem. I do it in this way. If you need more instructions I can give some. Bye, Lothar.
