21 years agoApplication Not Compling
I'm in the process of trying to get the simple "hello_world.c" code to run from the board using Linux. I have the kernel and filesystem built and installed on the board. I'm now trying to compile the hello_world.c code in an application project. Upon clicking build project I receive the following error:
Kind Status Priority Description Resource In Folder Location Error *** No rule to make target `hello.exe', needed by `all'. hello_world_app Now, I made the proper edit to the makefile I built (i.e. TOPDIR = .. to TOPDIR = ./) since the makefile and hello_world.c are at the same level. Below is my current Makefile code: TOPDIR = ./ include $(TOPDIR)/Rules.mak # # configurable options# - set DEBUG = 1 to turn on debugging support# DEBUG = 0 PROJ_NAME = hello INSTALL_DIR = PROGS := $(PROJ_NAME).exe CFLAGS += # # You should not need to modify anything beyond this point# ifeq '$(DEBUG)' '1' CFLAGS += -O0 -g PROGS += $(PROGS:.exe=.gdb) endif all: $(PROGS) .PHONY: clean clean: -rm -f *.[oad] *.elf *.gdb *.bin *.exe .PHONY: install install: all ifeq "$(INSTALL_DIR)" "" $(error No installation directory specified) endif mkdir -p $(INSTALL_DIR)/bin install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin I'm at a loss as to what could be causing this problem. My first thought would be the make target, but I created one for all. Any help here would greatly be appreciated. Thanks1 Reply
Ah, simple fix.
Original code: DEBUG = 0 PROJ_NAME = hello INSTALL_DIR = PROGS := $(PROJ_NAME).exe CFLAGS += I changed: PROJ_NAME = hello TO PROJ_NAME = hello_world Ok, I'm sure I'll have more questions regarding what I'm trying to do.
