12 years agoApplication jump to Bootloader
Hi, I need some help with triggering an application restart from bootloader. In my system I have an on-chip RAM (where bootloader resides) and an SRAM where application will be running. T...
12 years agoAltera named our boot-stages as BootROM, Preloader, U-boot or RTOS or Baremetal on 3th stage.
What you mean by "custom bootloader" ? And why mentioned Nios ? Usually 64K of onchip RAM is visible from 0 adress also, although he located on FFFF0000. However, some time I see BootROM on 0th disassembly and steped to it in DS-5 -- remapping may be used. If fill Custom Preloader with "while (1) ;" to flash and repower board, may connect to this endless cycle and continue running through changing PC... If application calls pure function pointer, then will be reboot of system. If to 0 mapped BootROM, will be full reboot.
