12 years agoApplication jump to Bootloader
Hi, I need some help with triggering an application restart from bootloader. In my system I have an on-chip RAM (where bootloader resides) and an SRAM where application will be running. T...
12 years agoHi,
For this use case, the boot copier used should be CFI based boot copier. The application should located just after the CFI based boot copier. Wonder is this the boot copier you used or your custom boot copier? Chin Liang
