21 years agoApplication code residing in the EPCS
Has anyone used the EPCS controller to hold 100% of your application code? We are pin limited and I was considering giving it a whirl. Any idea of how long the boot loader in the FPGA takes to copy...
21 years agoHi Alex,
So you have physically removed the large EPCS and replaced with an EPCS4 on your board? That tells me that, perhaps, the problem is in the board component you created to tell the flash programmer about your board/flash setup. I say "perhaps" because I cannot remember if the target-board setup utility asks you which EPCS device you have on your board; if that's the case you should re-run the target board setup utility and tell it about your EPCS4. By the way this problem has not gone un-noticed. I cannot give you a patch/hot fix right this moment but have filed a high-priority issue on what you report and located what needs to be changed in our tool-set.
