21 years agoApplication code residing in the EPCS
Has anyone used the EPCS controller to hold 100% of your application code? We are pin limited and I was considering giving it a whirl. Any idea of how long the boot loader in the FPGA takes to copy...
21 years agoI second Jesse's statement. There is no perceptible delay from hitting reset to the code running. The only problem you might run into is the size of your app. I'm using a Cyclone C6 and my code is under 200k and it uses 3 sectors of the EPCS. You might need a larger device than the EPCS4. I'm told that there are other serial flashes that are pin and protocol compatible with the EPCS series. But, I don't think the Altera tools support anything but the EPCS1 and EPCS4. Good luck.
