21 years agoAnyone using OCIDEC ?
Have anyone tried using the Opencores IDE controller instead of the Altera CF interface ?? I have a custom NiosII FPGA image w/OCIDEC, and have made the necessary changes to the uClinux 2.6.9 ke...
20 years ago --- Quote Start --- originally posted by lukequinane+jun 14 2006, 02:55 pm--><div class='quotetop'>quote (lukequinane @ jun 14 2006, 02:55 pm)</div>
--- quote start ---
<!--quotebegin-hippo@May 4 2006, 11:22 AM i have tested the altcf core with ide harddisk on many custom boards. --- Quote End --- hippo, how did you get the altcf core working with the IDE hard disks? I have a ep1s10 dev kit and when I boot up linux with an IDE drive plugged into the J11 connector it just says:
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=0 <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16167)</div> [/b] --- Quote End --- The cf example use cf socket, not ide header. Did you add the altcf component in sopc builder and assign the pins to regenerate sof?
