21 years agoAnyone using OCIDEC ?
Have anyone tried using the Opencores IDE controller instead of the Altera CF interface ?? I have a custom NiosII FPGA image w/OCIDEC, and have made the necessary changes to the uClinux 2.6.9 ke...
20 years ago --- Quote Start --- originally posted by hippo@May 4 2006, 11:22 AM i have tested the altcf core with ide harddisk on many custom boards. --- Quote End --- hippo, how did you get the altcf core working with the IDE hard disks? I have a ep1s10 dev kit and when I boot up linux with an IDE drive plugged into the J11 connector it just says:
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=0
