16 years agoAny experience with ping_app on niche-stack
Hello all,
has anyone experience with the ping-app within the niche-stack? How can a ping be started? How can i get the ping statistics? How to setup parameters like detination ip, timeout, ttl, data-size, etc? Is there any example code? :confused:1 Reply
Do you mean to ping niche stack from an external device or do you want niche stack to send a ping? Probably the second one, since the first one is the basic way of operation.
I never tried pining from iniche but I think it is quite simple. Try with send_arp() function. You'll find it in et_arp.c file in /altera.components/Nios II Software Packages/altera_iniche/UCOSII/src/ip/ If not this function, look in other files in the same ip directory.
