22 years agoAny example Master Ports available?
Hello, Altera or anyone else have an example demonstrating external master logic driving an SOPC system? I've got one "working" but only if I set a very low fmax. The particulars ar...
22 years agoHi Ken,
Just so you (and others) know, there is no difference in having user-logic inside the SOPC Builder system versus connected at the top level. Both approaches should synthesize to the same resultant logic. What I sent you, with the class.ptf file, just packages up some HDL code and tells SOPC Builder how to hook up each port - just as one would do manually in the interface-to-user-logic GUI. As I stated to you personally, that GUI is undergoing an overhaul and will have cababilities for more complex user-logic in the future. I am, however, tinkering with a design in my spare time that should be more applicable to your needs...
