22 years agoAny example Master Ports available?
Hello, Altera or anyone else have an example demonstrating external master logic driving an SOPC system? I've got one "working" but only if I set a very low fmax. The particulars ar...
22 years agoHi Kerri,
Jesse sent me example components but no working examples that use a UDL Master Port. I'm still looking at the ip_checksum example however. Is the point that bringing the UDL inside the SOPC system gives it better access to the Avalon bus than working through a UDL Master Port? My case is just like example 13 on page 53 of the Avalon Spec. Mike described it perfectly with Master-drives-Avalon port phrase. Did you get my project? The Master port is the SCAN_IN port. I annotated the bdf to point out the relevent blocks and signals. Thanks, Ken
