20 years agoanother application is using JTAG UART????
Hi: I boot uClinux on a customed board using the following steps. 1.load .pof file to configrure fpga 2. Build and upload kernel to sdram 3. Build and upload filesystem to flash 4.U...
20 years agothank you,wgoossens:
I have solved the problem with your way! But a new difficulty occurs: nios2-terminal displays messages“starting in terminal mode <control-C exit s>” but does't display log in prompt :( What should I do then? I'm sorry if my problems trouble you.
