20 years agoanother application is using JTAG UART????
Hi: I boot uClinux on a customed board using the following steps. 1.load .pof file to configrure fpga 2. Build and upload kernel to sdram 3. Build and upload filesystem to flash 4.U...
20 years ago --- Quote Start --- originally posted by fodywang@Nov 15 2005, 01:48 AM nios2-terminal: unable to connect to jtag uart because another application
nios2-terminal: (nios2-terminal on 127.0.0.1)
nios2-terminal: is using it (or is using something else which clashes). please c
lose
nios2-terminal: the other application and try again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10977)
--- quote end ---
--- Quote End --- Looks like you have another instance of nios2-terminal running. This could be a separate terminal or one inside nios2-ide. It's probably one inside the nios2-ide. Try to close that one and try again.
