19 years agoan UART programme
Hi there,I'm trying to delievering and recieving charactors by UART:while I recieve a charactor(for example:0x00),I delieve 0x01.Below is my C programme,could anyone tell me if there's any problems ?Thank you!
# include <unistd.h># include <string.h># include "system.h"# include "sys/alt_irq.h"# include "altera_avalon_uart_regs.h"# include "alt_types.h"# include "altera_avalon_uart.h"# include "altera_avalon_uart_regs.h"# define RRDY_MSK 0x0080# define TRDY_MSK 0x0080 //ISR for receiving and delievering static void uart_isr(void* context, alt_u32 id) { /* * Read the status register in order to determine the cause of the * interrupt. */ alt_u32 status; alt_u8 rxdata; status = IORD_ALTERA_AVALON_UART_STATUS(UART_0_BASE); /* Clear any error flags set at the device */ IOWR_ALTERA_AVALON_UART_STATUS(UART_0_BASE, 0); /* process a read irq */ if (status&ALTERA_AVALON_UART_STATUS_RRDY_MSK) { rxdata=IORD_ALTERA_AVALON_UART_RXDATA(UART_0_BASE); } /* process a write irq */ if (status&ALTERA_AVALON_UART_STATUS_TRDY_MSK) { IOWR_ALTERA_AVALON_UART_TXDATA(UART0_BASE, 0x01); } } int main() { //enable the uart_0 interrupt IOWR_ALTERA_AVALON_UART_CONTROL(UART_0_BASE,ALTERA_AVALON_UART_CONTROL_RRDY_MSK| ALTERA_AVALON_UART_CONTROL_TRDY_MSK); //Register the interrupt handler alt_irq_register(UART_0_IRQ,0,uart_isr); if(rxdata) { IOWR_ALTERA_AVALON_UART_TXDATA(UART0_BASE, 0x01); } return 0; }4 Replies
--- Quote Start --- originally posted by cicizhang@Dec 18 2006, 08:07 PM hi there,i'm trying to delievering and recieving charactors by uart:while i recieve a charactor(for example:0x00),i delieve 0x01.below is my c programme,could anyone tell me if there's any problems ?thank you!# include <unistd.h># include <string.h># include "system.h"# include "sys/alt_irq.h"# include "altera_avalon_uart_regs.h"# include "alt_types.h"# include "altera_avalon_uart.h"# include "altera_avalon_uart_regs.h"# define rrdy_msk 0x0080# define trdy_msk 0x0080
//isr for receiving and delievering
* read the status register in order to determine the cause of the
* interrupt.
alt_u32 status;
alt_u8 rxdata;
status = iord_altera_avalon_uart_status(uart_0_base);
/* clear any error flags set at the device */
iowr_altera_avalon_uart_status(uart_0_base, 0);
if (status&altera_avalon_uart_status_rrdy_msk)
rxdata=iord_altera_avalon_uart_rxdata(uart_0_base);
if (status&altera_avalon_uart_status_trdy_msk)
iowr_altera_avalon_uart_txdata(uart0_base, 0x01);
int main()
iowr_altera_avalon_uart_control(uart_0_base,altera_avalon_uart_control_rrdy_msk|
altera_avalon_uart_control_trdy_msk);
//register the interrupt handler
alt_irq_register(uart_0_irq,0,uart_isr);
if(rxdata)
return 0;
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20090)
--- quote end ---
--- Quote End ---
Please explain again what would you like to accomplish, and what do you get instead.
IzI - Altera_Forum
Thank you .I tried to make an interrupt of receiving charactors,and then delievering what I've received.I had problems with baud rate,it was because I forgot to change the property to baut rate changeable,now it's OK.Thank you again.
<div class='quotetop'>QUOTE (cicizhang @ Dec 20 2006, 08:00 PM) <{post_snapback}> (index.php?act=findpost&pid=20140)</div>
--- Quote Start --- Thank you .I tried to make an interrupt of receiving charactors,and then delievering what I've received.I had problems with baud rate,it was because I forgot to change the property to baut rate changeable,now it's OK.Thank you again.[/b] --- Quote End --- I try the programme accoring to which you provided,I meet the same question as you, But I understand how you resolve it Can you describe concretely!!!
