20 years agoAn error during compiling
hi,
i'm a freshman in embedded.my target board is cyclone2 ep2c35(with 48k total ram bits on chip,105 M4k memory blocks). the components i added into my design as follows: a processor,on chip memory(16kbytes ram) ,lcd_display,jtag uart,pio my program :# include "alt_types.h"# include <stdio.h># include <unistd.h># include "system.h"# include "sys/alt_irq.h"# include "altera_avalon_pio_regs.h" ... FILE * lcd; lcd = fopen("/dev/lcd_display", "w"); ....... i select "small C library" and "reduced device drivers" options i encounter two questions while compiling 1)i can't use the fopen function,the error msg during compiling: obj/count_binary.o(.text+0x98): In function `main': ../count_binary.c:22: undefined reference to `fopen collect2: ld returned 1 exit status make: *** [count_binary_3.elf] Error 1 Build completed finally i use printf instead.and the program can run on the "nios/s" core; when i run it on my core descibed above, i came across another problem 2) Linking count_binary_3.elf... /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/ gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: region onchip_memory_0 is full (count_binary_3.elf section .text). Region needs to be 42168 bytes larger. /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/ gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: region onchip_memory_0 is full (count_binary_3.elf section .rwdata). Region needs to be 652 bytes larger. /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/ gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: section .rodata [00000020 -> 00000737] overlaps section .exceptions [00000020 -> 000001c7] /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/ gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: section .rwdata [00000738 -> 0000228b] overlaps section .text [000001c8 -> 0000c4b7] /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/ gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: section .bss [00000020 -> 00000257] overlaps section .exceptions [00000020 -> 000001c7] obj/count_binary.o(.text+0xc8): In function `count_lcd': ../count_binary.c:60: Unable to reach (at 0x00000034) from the global pointer (at 0x0000a210) because the offset (-41436) is out of the allowed range, -32678 to 32767. is it necessary to add an extern memory? if yes,how can i do it?because i looked through the nios2 sw&hw dev handbook but can't find the introduction of steps to add a extern ram can anyone help me? thank u for your attention2 Replies
I think you ran out of onchip memory... (it's one of the first error messages)
There are many examples distributed by Altera that shows how external RAMs can be used... just start from them! bye Paolo - Altera_Forum
<div class='quotetop'>QUOTE </div>
--- Quote Start --- i select "small C library" and "reduced device drivers" options i encounter two questions while compiling 1)i can't use the fopen function,the error msg during compiling: obj/count_binary.o(.text+0x98): In function `main': ../count_binary.c:22: undefined reference to `fopen collect2: ld returned 1 exit status make: *** [count_binary_3.elf] Error 1 Build completed[/b] --- Quote End --- I guess you shouldn't enable small C library property if you want to use 'fopen'. FYI. regards, David
