21 years agoAMD FLASH PROBLEM S29GL064M11TAIR0
AMD FLASH PROBLEM because it was difficult to buy an AMD FLASH AM29LV065DU-120REI, AMD recommended to use the newer S29GL064M11TAIR0, which is pin compatible and CFI compliant. Now w...
21 years agoHello,
do you have more information, about the support for the S29GL128M from AMD ? I plan to use a S29GL256M, and I would like to know wheter the Flash programmer can be used (and the MTD driver under uClinux). Another question : Since I want to set a JFFS2 on that flash, what will give me the best performance : using it in byte mode or in word mode ? Thanks for you answer, pod
