21 years agoAMD FLASH PROBLEM S29GL064M11TAIR0
AMD FLASH PROBLEM because it was difficult to buy an AMD FLASH AM29LV065DU-120REI, AMD recommended to use the newer S29GL064M11TAIR0, which is pin compatible and CFI compliant. Now w...
21 years agoagain ide flash programmer problem
hi mike, yes I can leave the room twice,turn mysel 10 times and then if the ide is happy with the target board and i can start programming, it stops with the error message above, because the script generated by the ide is wrong. !!! I do not understand, why there is no input box in the flashprogrammer tool !!! where I can enter the path to the board sof-file !!! from where does the ide flashprogrammer get's the information for the board.sof file ??? in my case the ide flashprogrammer writes the script flash_programmer.sh -- the path "--sof=/system/BOARD_12DIXI02.sof" is wrong --sof=__NO_SOF_PLEASE__ is wrong
