21 years agoAMD FLASH PROBLEM S29GL064M11TAIR0
AMD FLASH PROBLEM because it was difficult to buy an AMD FLASH AM29LV065DU-120REI, AMD recommended to use the newer S29GL064M11TAIR0, which is pin compatible and CFI compliant. Now w...
21 years agoFLASH TYPES PROBLEM (S29GL064M):
you are right, the document from your link for S29GLxxxa really has the word programming command, but when I look at the TSOP package, it seems not to be pin compatible with type Am29LV065D. the type which AMD recommended to use is not this type (S29GL064A) , it is S29GL064M, see http://www.amd.com/us-en/assets/content_ty...xxm_00_b3_e.pdf (http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/s29glxxxm_00_b3_e.pdf) and look there at the command table, there is no word programming mode. I am a little bit confused, I thought that "CFI compliant" means "software compatible".
