20 years agoAM29LV065D FLASH read, erase, program?
Hi All, Does anyone know how to read erase and program the AMD flash memory in ucLinux using C programs? (AM29LV065D or AM29LV128MH) I use this memory for store uClinux FPGA SOF and user’s...
20 years agoHi posix6973,
> 1. I didn’t see any mtd device file create in /dev. Did I missing some procedures? You need to do this when you create the file system. You have two choices: (1) Create the device inodes by hand using mknod, then run mkfs.jffs2 (2) Create a device table file and use the -D, --devtable option to mkfs.jffs2 The second option is very convenient since you don't need to be root, and you basically have built-in documentation for /dev ;-) > 2. Need I create the mtd-utils with kernel? No. Just download and build the applications like any other linux apps. > 3. What difference between ROMfs and romfs/jffs2 in boot report? It looks like you are using two different mtd mapping drivers. Take a look at: drivers/mtd/maps/altera.c. drivers/mtd/maps/nios_romfs.c Regards, --Scott
