21 years agoALTPLL Problem
After changing the ALTCLOCKPLL’s in the standard vhdl example design to ALTPLL’s everything still worked fine. But when I changed the ratio on the e0 output of the controller_pll from 1/1 to 4/5 my p...
21 years agoJesse,
What exactly do you measure on the scope? Our custom board uses the same sdram as the Cyclone devkit and I had to remove the delay to get it to work. (Nice since I only need one pll) I tested it to 120 MHz with no read/write errors, but I'm wondering if I could optimize it further if I measured and added just the right delay. Thanks, Ken
