11 years agoALTPLL Megawizard crashes
I have an ALTPLL in my design. When I try to change it, the Megawizard gets to the 2nd screen, then stops responding to input. After a while, a pop-up comes along and says that it's not re...
11 years agoHi d_s_klein,
What device are you working on? the ALTPLL if the PLL IP for either IV series or the MAX10... Have you tried to create a new PLL ip based on the device IP catalogue (if you are in QII 15.0) or generate a new PLL through the megawizard (if you are planning to use the QII 13.1)
