21 years agoALTERA's SDRAM - Only 2 words bursrt?
Hi All,
I am trying to use the SDR SDRAM controller that is comming with the NIOS II development package. In the simulation it looks like this core supports only 2 words bursts. I couldn't find anything in the documentations. Am I correct? If this core supports bigger bursts then 2 words, any ideas what am I doing wrong? Thank you all Zohar1 Reply
Hi Zohar,
As far as I know, the SDRAM controller which comes with Nios has no burst mode support at all (that is, other value than 0 for bits 0..2 in the mode register), or in other words the burst is fixed at 1. However, reading or writing at/to the same row will not trigger a precharge so you get one read/write per clock. A bit more info you can find in the Nios II Processor Reference Handbook - chapter 5.
