22 years agoALTERANiosII examples work on MicrotronixCyclone ?
Hi, I just got my new ALtera NIOS II CDROM (eval version) and i'm trying to run the Cyclone's "standard" example's hello_world . I'm following the QUICK START GUIDE in the ...
22 years agoThen, I also tried the same steps but using the "low_cost" hello_world example (also for Cyclone),
but got different error message below. Is the USB JTAG cable really needed for NIOSII kit rather than the old ByteBlasterMV [LPT1] ? are both error messages (here and from my previous post) caused by this same USB cable or separate issue? Thanks # ### nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information. nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "ByteBlasterMV [LPT1]", device 1, instance 0 nios2-terminal: starting in terminal mode only (Control-C exits)
