21 years agoAltera/Microtronix C12 Evaluation Kit questions
"hello_led" example worked fine, but when I tried to test a simple VHDL code without using SOPC and Nios II processor, it didn't work. The code simply try to toggle the LEDs by buttons or a cou...
21 years agoI have a quick suggestion, don't know if it will help.
Go into the "Device & Pin Options..." window on the device selection page. Go to the "Unused Pins" tab and make sure the the "As inputs, tri-stated" option is selected. This may not be your problem, but I've seen it a few times in the past with symptoms similar to yours. Dennis Scott Microtronix Datacom Ltd.
