21 years agoAltera zip read-only filesystem
Hello, I am trying to use the Altera zip read-only fileysystem on an altera development kit. I can run the app okay when in debug mode but after flash programmed into the flash, the system does n...
21 years agoLiangyi,
You're "barking up the wrong tree". 1. The zip file system will only over-write the application if the offset you chose for the zip file system overlaps the application. 2. You should not change the zip file location in a .sh file, this will not change the# defines which are used for the code. You should change the location of the file system by right clicking on your application project, then selecting System Library properties. The select Software Components and the read only zip filing system, in here you can set the offset.
