21 years agoAltera zip read-only filesystem
Hello, I am trying to use the Altera zip read-only fileysystem on an altera development kit. I can run the app okay when in debug mode but after flash programmed into the flash, the system does n...
21 years agorugbybloke- your method worked. The app ran with no problem after moving the flash file slightly after the end of the application. Now I don't overrun into the factory safe image.
scs- I have tried that with another project, but for this particular one I needed a simple read only filesystem that might contain several files and so it was easier to use the altera file sys for now. thanx again for all your suggestions. -Quan ps. now if I can only get this dma to behave like it did in the nios 3.01 days then i would really be in a happy mood...
