21 years agoAltera zip read-only filesystem
Hello, I am trying to use the Altera zip read-only fileysystem on an altera development kit. I can run the app okay when in debug mode but after flash programmed into the flash, the system does n...
21 years agoscs,
Yes what you suggest will get a .zip file into the code. However it will not be available for use by the Altera Read Only Zip Filing System which is what the original question was about!!
