16 years agoAltera TSE support (EXPERIMENTAL) + GMII ??
Hi all, I was wondering which interface we must use between the TSE MAC and the PHY when the following option is selected in "make menuconfig" : [*] altera tripple speed ethernet support...
16 years agoyou should confirm the interface mode,and make sure the corresponding work timing is correct, and you can test the timing when the ethernet is up by signal tap II! good luck!
