15 years agoAltera TSE on NEEK with web_server_neek demo design
Hi, I want to get started with Linux on my NEEK Board, and tried the example design from the wiki: http://www.nioswiki.com/linux/creating_a_nios_ii_design_with_an_mmu (The Webserver Example). I...
15 years ago --- Quote Start --- As I wrote above, fixing the MII address of the PHY did the job, but thank you. When I get my NEEK back I'll give your file a try. Regards, Andreas --- Quote End --- I am attempting to make a Cyclone II plus DP83848 work and am running into the same error you list. I searched the file you referenced and made the change (line numbers have moved again) but it did not fix the problem for me. I have two different systems with a Cyclone + DP83848 and I cannot get networking up on either. Any wisdom welcome. David
