16 years agoAltera TSE driver and example program for lwIP (1.3.2)
After many many requests and complaints about lack of support and/or documentation for support of lwIP for the Altera TSE, I have developed a drop-in TSE driver and example program and made this avai...
12 years ago --- Quote Start --- I removed (all?) the bugs (The 4 byte SGDMA bug is available in code, but I didn't enable it yet, because I haven't seen any problems) and added multiple PHY support. If you are interested in using this BSP you will have to read the README and the lwip_main.h file to see how you can implement it. Please have a look at : https://github.com/engineeringspirit/freelwip-nios-ii if you're interested in an FreeRTOS with LwIP BSP for in your Nios II IDE (tested with 11.0 till 12.0sp1) --- Quote End --- Is there an off-the-shelf development kit (altera, terasic, etc) that this will work out of the box with? I understand a TSE must be instantiated, but what kind of PHY chip? I think BillA used the Marvell 88E1119R in the lwip port, but I believe it was a custom cyclone3 board. If no COTS, is there any tips on the thought process involved in porting the design to different phys?
