16 years agoAltera TSE driver and example program for lwIP (1.3.2)
After many many requests and complaints about lack of support and/or documentation for support of lwIP for the Altera TSE, I have developed a drop-in TSE driver and example program and made this avai...
12 years ago --- Quote Start --- This kind of error typically means the hardware definition is wrong. Something is wrong with memory, clocks, speeds or something. In the past I've told people that have problems with this example to get a standard Altera example running - like Simple Socket Server as-is on your hardware (create app and BSP with that template). If the Simple Socket Server won't run, this lwIP example will never run either. It's pretty hard to test and debug software with unstable hardware. BillA --- Quote End --- Hi Billa thanks for your reply my board can ping it,and my hardware have sth wrong? I will check the hardware with the SSS project. best wishes to you!
